Einleitung
A replacement of the power supply unit is needed if the projector shows no sign of power despite the use of a functional power cable. It is located within the Epson Home Cinema 2150 almost at middle right next to the projector lens. It's a heavy black box.
The power supply is designed to deliver the proper power to the projector.
Was du brauchst
Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
Unscrew the single 6mm Phillips#2 holding screw from the access panel.
Slide the panel horizontally, then lift up to remove the access panel.
Loosen and remove the two screws holding the lamp.
Remove two 9 mm Phillips #2 screws.
Remove the air filter cover. Grip the piece with two fingers above and below at the center.
Grab the air filter from the protruding tab and pull the filter out.
From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
Remove two 6 mm Phillips #1 screws.
Pull off remaining plastic molding.
Pull the clips on the case with two fingers on opposite ends and remove the case.
Pull up on the rear panel retaining clip.
Pull the rear panel away from the device to remove.
Remove two 5 mm Phillips #1 screws.
Press on the metal connector and firmly pull to remove the remaining ribbon cable.
Remove twelve 5 mm Phillips #1 screws.
Using both hands, carefully lift the first half of the motherboard.
Disconnect the three brown ribbon connectors from the board.
Remove four 5 mm Phillips #1 screws.
Remove two 3 mm Phillips #1 screws.
Pull upwards on the motherboard to remove it from the projector.
Remove the 7.5 mm Phillips #1 screw.
Set the black plastic lens sliders to the side.
Remove five 9.5 mm Phillips #1 screws.
Remove one 6.0 mm Phillips #2 screw.
Remove the metal bracket by pulling upwards on its sides.
Remove the 9.5 mm Phillips #1 screw located behind the power supply.
Remove the 10 mm Phillips #1 screw.
Move the fan cable to the side for clear access to the sensor below it.
Using pliers, pull upwards on the white sensor to remove it from the fan assembly.
Carefully lift upwards on the fan assembly to remove the fan from the projector.
The power supply unit is a black box. Inside, there are two connected circuit boards, each with a single connector.
Using needle nose pliers, disconnect the first white connection cable from the circuit board.
From the rear side of the power supply unit, remove a single 9.5 mm Phillips #1 screw.
Carefully lift the power supply unit 2-3 inches upwards without creating tension on the remaining wires.
Angle the power supply unit to the side for clear access to the remaining connector.
Using needle nose pliers, disconnect the remaining wires from the power supply connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
