Einleitung
If no wireless functions are responding, the projector’s wireless connection board may be broken. This component is located inside the projector above the supply power box which is located near the projector lens.
Was du brauchst
Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
Unscrew the single 6mm Phillips#2 holding screw from the access panel.
Slide the panel horizontally, then lift up to remove the access panel.
Loosen and remove the two screws holding the lamp.
Remove two 9 mm Phillips #2 screws.
Remove the air filter cover. Grip the piece with two fingers above and below at the center.
Grab the air filter from the protruding tab and pull the filter out.
From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
Remove two 6 mm Phillips #1 screws.
Pull off remaining plastic molding.
Pull the clips on the case with two fingers on opposite ends and remove the case.
