Zum Hauptinhalt wechseln
Epson PPC650 Camera Case Replacement
Was du brauchst
  1. Epson PPC650 Camera Case Replacement, Case: Schritt 1, Bild 1 von 3 Epson PPC650 Camera Case Replacement, Case: Schritt 1, Bild 2 von 3 Epson PPC650 Camera Case Replacement, Case: Schritt 1, Bild 3 von 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Camera Case Replacement: Schritt 2, Bild 1 von 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Camera Case Replacement: Schritt 3, Bild 1 von 2 Epson PPC650 Camera Case Replacement: Schritt 3, Bild 2 von 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Camera Case Replacement: Schritt 4, Bild 1 von 1
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Camera Case Replacement: Schritt 5, Bild 1 von 3 Epson PPC650 Camera Case Replacement: Schritt 5, Bild 2 von 3 Epson PPC650 Camera Case Replacement: Schritt 5, Bild 3 von 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
Abschluss
Brittany
101 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Buehl Spring 2013 Mitglied von Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 148
