Zum Hauptinhalt wechseln
Epson Perfection V33 Glass Cleaning Process
Was du brauchst
    • Open up the lid to the flatbed scanner.
    • It can help with the next step if you lift it so it bends out flat to the other side.
    Frag FixBot
    Kommentar hinzufügen
  1. In diesem Schritt verwendetes Werkzeug:
    • On each side of the open hinge there are two large Phillips screws on either side.
    • Use a Phillips screwdriver to unscrew them and lift them out with tweezers.
    • Be careful and avoid dropping the screws on the scanning glass so you don't scratch it.
    Frag FixBot
    • Gently lift the top casing of the scanner up from the side where you unscrewed the area around the lid hinge, at the corner opposite to where the buttons are located.
    • While holding it up at an angle like that, slide the casing towards the opposite side of the hinge.
    • The top casing can now be gently lifted off.
    Frag FixBot
    • Use a glass cleaner (as instructed on the bottle) to clean off any fungal growths or particles off of the underside of the glass, then dry with a lint-free cloth.
    • There you go! All gone.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 888
