Zum Hauptinhalt wechseln
Epson PowerLite 822 Plus Exhaust Fan Replacement
Was du brauchst
  1. Epson PowerLite  822 Plus Exhaust Fan Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 2, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 2, Bild 2 von 2
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 3, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 4, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 4, Bild 2 von 2
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 5, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 6, Bild 1 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 6, Bild 2 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 6, Bild 3 von 3
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 7, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 7, Bild 2 von 2
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 8, Bild 1 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 8, Bild 2 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 8, Bild 3 von 3
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 9, Bild 1 von 1
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: Schritt 10, Bild 1 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: Schritt 10, Bild 2 von 3 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: Schritt 10, Bild 3 von 3
    • Unscrew the four 6mm screws that hold together the fan bracket.
  11. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 11, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 11, Bild 2 von 2
    • Unscrew the four 6mm screws that secure the projector.
  12. Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 12, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: Schritt 12, Bild 2 von 2
    • Pull out the loose projector.
  13. Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: Schritt 13, Bild 1 von 2 Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: Schritt 13, Bild 2 von 2
    • Gently lift the fan bracket up and remove it and it is ready to be replaced.
Abschluss
Emma Richey
915 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 90
