Einleitung
This is a replacement guide for the motherboard for the Epson PowerLite 822+. Model number EMP-822H. When the motherboard is not working as it should it can cause the projector to not turn on. This guide will show you how to remove and replace the current motherboard in your projector.
Was du brauchst
Flip the projector over.
Remove all 8 screws on the bottom of the projector.
Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
Now completely take off the top of the projector.
Now, the motherboard is completely removed from the projector and you are ready to replace it.
