Einleitung
To replace many of the components on the Epson PowerLite Home Cinema 1040, you must first start by removing the projector housing. This guide contains the step by step instructions to remove this housing and access the inner components of the projector.
Was du brauchst
Use the Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
Slide off the lamp cover and remove it from the projector.
Use the Phillips #1 (PH1) screwdriver to remove the three 7 mm screws around the perimeter of the lens cover.
Remove the air filter cover.
Remove the two PH1 7mm screws from under the air filter cover.
Flip the projector so the bottom is exposed.
Remove seven PH1 7mm screws on the outer rim of the projector.
Remove the cover on the backside of the projector where the inputs are located.
Using your fingernail or another thin wedging tool, disconnect the electronic strip from the motherboard.
Remove the top half of the projector housing completely and set it to the side.
