Zum Hauptinhalt wechseln
Epson Stylus NX230 Ink Cartridge Replacement
  1. Epson Stylus NX230 Ink Cartridge Replacement, Ink Cartridge: Schritt 1, Bild 1 von 1
    • Open the top of the printer so that the inside of the printer is visible. Press the red button.
    • The ink cartridges should be visible.
  2. Epson Stylus NX230 Ink Cartridge Replacement: Schritt 2, Bild 1 von 1
    • Grab the top of the cartridge that you need to replace and press in on the tab at the top of the cartridge.
    • Pull the cartridge up and out of the ink tray
Abschluss
Close the cover and hit the red button one last time. It will now move to the park position and "CHARGE" the cartridges.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 6-1, Forte Spring 2014 Mitglied von Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
4 Mitglieder
10 Anleitungen geschrieben
9 Kommentare
I tried cartridge 124 and 125 in black only (and it says ink cartridge not recognized and won't print even if the black cartridges are full). But I left the color ones empty! Do ALL of the cartridges have to be full in order for the printer to work?? I only do black and white print jobs so it doesn't make sense for me to buy color ink. Thanks a lot!!
kathleenngomez - Antwort
no idea why replacing these cartridges was so confusing to me - but this article REALLY helped, thank you!
hi - Antwort
When I tried these instructions the very first thing I tried did not work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Doris Crowley - Antwort
When I tried these instructions the very first thing I tried did no work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 11,381
