Zum Hauptinhalt wechseln
Epson Stylus NX230 Motherboard Replacement
Was du brauchst
  1. Epson Stylus NX230 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motherboard Replacement: Schritt 2, Bild 1 von 2 Epson Stylus NX230 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motherboard Replacement: Schritt 4, Bild 1 von 2 Epson Stylus NX230 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motherboard Replacement: Schritt 5, Bild 1 von 2 Epson Stylus NX230 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motherboard Replacement: Schritt 6, Bild 1 von 3 Epson Stylus NX230 Motherboard Replacement: Schritt 6, Bild 2 von 3 Epson Stylus NX230 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kimberly Pugel
404 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-1, Forte Spring 2014 Mitglied von Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 1,145
