Einleitung
The buttons located on the side panel of the printer help communicate with functions that need to be performed such as scanning, copying, printing photos and turning the device on and off. Sometimes these buttons get stuck and need to be cleaned or replaced.
  1. Go to the left side of the printer and locate the control panel with the buttons on it. Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  5. After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  6. Flip over the plastic part of the now separated control panel.
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  7. All parts should be separate now to clean or replace.
    • All parts should be separate now to clean or replace.
Abschluss
Joshua Fabel
101 Reputation
1 Anleitung geschrieben
University of Maine, Team 2-4, Diaz Fall 2016 Mitglied von University of Maine, Team 2-4, Diaz Fall 2016
UMAINE-DIAZ-F16S2G4
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 214
