Zum Hauptinhalt wechseln
Epson Stylus Photo 1400 Ink cartridge replacement
Was du brauchst
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: Schritt 1, Bild 1 von 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: Schritt 1, Bild 2 von 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: Schritt 2, Bild 1 von 2 Epson Stylus Photo 1400 Ink cartridge replacement: Schritt 2, Bild 2 von 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: Schritt 3, Bild 1 von 2 Epson Stylus Photo 1400 Ink cartridge replacement: Schritt 3, Bild 2 von 2
    • Close cartridge cover.
    • Close cover of the printer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Larry Huang
1.004 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 17-11, Regan Fall 2011 Mitglied von Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Mitglieder
12 Anleitungen geschrieben
5 Kommentare
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Antwort
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Antwort
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Antwort
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Antwort
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 10,070
