Einleitung
Replacing your printer buttons.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. To remove the top cover of the printer you have to first release it from several tabs.
    • To remove the top cover of the printer you have to first release it from several tabs.
    • Note: This may take more than one person to complete.
  2. These three are the easiest tabs to remove. They are located on the back side of the printer.
    • These three are the easiest tabs to remove. They are located on the back side of the printer.
    • Push the tab in with one of the plastic opening tools.
    • Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
    • Repeat this process with the furthermost right tab, then proceed with the middle tab.
    • Note: It is recommended that step 3 and step 4 be completed simultaneously. The tabs are identical just on opposite sides.
    • Viewing from the front of the printer, there is a tab in the lower left corner.
      • Viewing the tab hole from the bottom of the printer.
      • Insert the mini screwdriver into the marked hole and pry out the tab.
      • Push in towards the blue sticker of the printer while pulling up on the case at the same time. Use one of the tools to keep the tab pried open.
    • This tab is the easiest to break so be very careful.
    • There is another tab in the right corner of the printer (viewing from the front).
      • Viewing the tab hole from under the printer.
      • Zoomed in on the tab hole.
    • Follow the same instructions in step 3 to remove this tab.
    • The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
    • The release points for the tabs are located in holes on the depressed area of the base (darker piece).
      • Use the mini screwdriver to pry out the tab.
      • Use one of the plastic tools to keep the tab pried out. Once it releases push in towards the printer (viewing from the side) and pull up on the case.
    • All of the tabs have now been released.
    • When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
    • Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
    • Now, pull the cover up and off.
    • Once your top cover is removed, locate your buttons.
    • Push these tabs in and pull up on the whole button piece to remove.
Abschluss
Brandon Ivy
Mitglied seit 11.04.2011
27 Reputation
1 Anleitung geschrieben
Cal Poly, Team 20-68, Walters Spring 2011 Mitglied von Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 887
