Zum Hauptinhalt wechseln
Epson Stylus Photo 820 Ink Cartridges Replacement
  1. Epson Stylus Photo 820 Ink Cartridges Replacement, Ink Cartridges: Schritt 1, Bild 1 von 1
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 2, Bild 1 von 2 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 2, Bild 2 von 2
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 3, Bild 1 von 2 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 3, Bild 2 von 2
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 4, Bild 1 von 3 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 4, Bild 2 von 3 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 4, Bild 3 von 3
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 5, Bild 1 von 3 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 5, Bild 2 von 3 Epson Stylus Photo 820 Ink Cartridges Replacement: Schritt 5, Bild 3 von 3
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alex Lin
99 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 20-68, Walters Spring 2011 Mitglied von Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 2,885
