Zum Hauptinhalt wechseln
Equity Alarm Clock 13014 Alarm Switch Replacement
Was du brauchst
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: Schritt 1, Bild 1 von 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: Schritt 1, Bild 2 von 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: Schritt 1, Bild 3 von 3
    • Remove the battery door using your finger nail or an opening tool.
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: Schritt 2, Bild 1 von 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: Schritt 3, Bild 1 von 1
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: Schritt 4, Bild 1 von 2 Equity Alarm Clock 13014 Alarm Switch Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: Schritt 5, Bild 1 von 2 Equity Alarm Clock 13014 Alarm Switch Replacement: Schritt 5, Bild 2 von 2
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alaa
311 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 1,079
