Einleitung
Are the buttons on your radar not responsive? If so, the button board could be damaged. Follow this guide to replace your button board.
Was du brauchst
Remove the three 1.2 mm Phillips #1 screws on the back of the device.
Carefully pry the grey frame off the black plastic covering using the nylon spudger.
Detach the orange flap on the motherboard.
Carefully remove the motherboard from the grey plastic frame.
Fast fertig!
Abschluss
