Einleitung
Are the buttons on your Escort Radar 9500IX's cracked or jammed? If this is the case, then follow this guide to replace the buttons on your radar.
Was du brauchst
Remove the three 1.2 mm Phillips #1 screws on the back of the device.
Carefully pry the grey frame off the black plastic covering using the nylon spudger.
Ein Kommentar
Ummm where/how do you get the replacement buttons. Mine are just simply non legible from wear and tear, yet still works perfectly.
