Einleitung
Is your radar's display not powering on or just hangs on a black screen? If this is the case, then the display could be at fault. Follow this guide to replace the display on your radar.
Was du brauchst
Remove the three 1.2 mm Phillips #1 screws on the back of the device.
Carefully pry the grey frame off the black plastic covering using the nylon spudger.
Detach the orange flap from the motherboard using a nylon spudger.
Carefully remove the motherboard from the grey plastic frame.
Detach the remaining two orange flaps from the circuit board that is attached onto the grey frame.
