Einleitung
If the device's screen has distorted images, or is blank and the troubleshooting guides don't seem to fix it, or if the device's screen is cracked, this guide will explain how to replace it.
Was du brauchst
Inser the flat end of a spudger into one of the two notches and pry off the case.
Slide the spudger around the perimeter of the radar housing until the case separates.
Remove the four 9mm Phillips #1 screws from the bottom of the radar.
Remove the bottom case.
Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
Push the two black tabs down to release the ribbon attached to the display.
The display ribbon should now easily slip out from under the white strip.
3 weitere Personen haben diese Anleitung absolviert.
12 Kommentare zur Anleitung
Kelsey, Where do you get the part? I need a replacement screen for my Passport Max FB30947A3. Escort customer service won’t sell it to me and requires me to send the unit to them for a bog fee.
I need a display screen for a max 2
Where can a replacement screen be ordered?
