Einleitung
Zu Schritt 1 der Anleitung ↓Sometimes the outer case of the device can become cracked or damaged. This guide will show you how to remove the outer case.
Was du brauchst
Werkzeuge
Spudger4.9
Inser the flat end of a spudger into one of the two notches and pry off the case.
Slide the spudger around the perimeter of the radar housing until the case separates.
To reassemble your device, simply place the pieces in their original places, and gently snap them closed.
Eine weitere Person hat diese Anleitung absolviert.
