Einleitung
This will teach you to uninstall and reinstall a laser from the motherboard. This is needed if the laser stops working and cannot be turned on by pressing the button to do so. The tools required will be a screwdriver and a soldering iron. The soldering iron is hot and may cause a potential hazard. For those who are uncomfortable soldering, there is a link to a soldering guide in the Troubleshooting section of the device page.
Was du brauchst
Pull the battery cover away from the handle by gripping near the thumb groove.
Disconnect the battery by pulling the connector away from it.
Positive first
Negative second
Realign the buttons with the button terminals.
Red terminal to red button.
Orange terminal to orange button.
Yellow terminal to yellow button.
Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
