Einleitung
This guide will show how to remove everything from the motherboard and have it by itself for replacement. This guide should only be necessary if nothing else works. It is a last resort as the motherboard is the least likely to malfunction. The tools needed are a screwdriver and soldering iron. The soldering iron will become very hot, so that is a potential hazard. For those who are not comfortable soldering, there is a link to a soldering guide in the Troubleshooting section of the device page.
Was du brauchst
Pull the battery cover away from the handle by gripping near the thumb groove.
Disconnect the battery by pulling the connector away from it.
Positive first
Negative second
Realign the buttons with the button terminals.
Red terminal to red button.
Orange terminal to orange button.
Yellow terminal to yellow button.
Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
Carefully pull the motherboard out of its slot in the body of the device.
