Zum Hauptinhalt wechseln
Ethernet Port Replacement
Was du brauchst
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: Schritt 1, Bild 1 von 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: Schritt 1, Bild 2 von 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: Schritt 1, Bild 3 von 3
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: Schritt 3, Bild 1 von 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: Schritt 4, Bild 1 von 3 Ethernet Port Replacement: Schritt 4, Bild 2 von 3 Ethernet Port Replacement: Schritt 4, Bild 3 von 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: Schritt 5, Bild 1 von 3 Ethernet Port Replacement, Ethernet Ports: Schritt 5, Bild 2 von 3 Ethernet Port Replacement, Ethernet Ports: Schritt 5, Bild 3 von 3
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: Schritt 6, Bild 1 von 1
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Denis
584 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 11-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 90
Insgesamt: 7,033
