Einleitung
This guide will teach you how to access the motherboard in order to replace the Ethernet ports.
Was du brauchst
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
Use a blue plastic opening tool to remove the top cover.
Move the blue plastic opening tool gently underneath the top cover from side to side.
Gently lift the motherboard and remove it from the case
Put the motherboard over a (preferably white) surface.
Locate the Ethernet ports
Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
Melt the 40 solder points using a soldering gun.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
