Einleitung
If your AM Radio is not receiving signal, then you may be in a deadzone or it might be broken. If it is damaged, you will need to follow this guide to replace it.
Was du brauchst
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
Remove the two Phillips #00 screws located in the center of the back of the device.
On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
Unplug the socket connection from the motherboard as shown in the image.
Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
On the back of the motherboard, remove the two Philips #0 screws.
Turn the circuit board back over. Proceed to desolder the two thin wires from the AM antenna, that are soldered to the circuit board.
Gently pull the AM antenna straight up, out of its housing, to remove it from the circuit board.
To reassemble your device, follow these instructions in the reverse order.
