Zum Hauptinhalt wechseln
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: Schritt 1, Bild 1 von 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
Abschluss
To reassemble your device, follow these instructions in the reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-6, Nance Spring 2016 Mitglied von USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 Mitglieder
13 Anleitungen geschrieben
4 Kommentare
My question is where can you find an FRX3 replacement battery?
jalwitt - Antwort
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Antwort
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 5,316
