Zum Hauptinhalt wechseln
Eton FRX3 Solar Panel Replacement
Was du brauchst
  1. Eton FRX3 Solar Panel Replacement, Rechargeable Battery Pack: Schritt 1, Bild 1 von 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Solar Panel Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Solar Panel Replacement, Case Assembly: Schritt 3, Bild 1 von 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Solar Panel Replacement: Schritt 4, Bild 1 von 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Solar Panel Replacement: Schritt 5, Bild 1 von 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Solar Panel Replacement: Schritt 6, Bild 1 von 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Solar Panel Replacement: Schritt 7, Bild 1 von 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 Solar Panel Replacement, Solar Panel: Schritt 8, Bild 1 von 1
    • The solar panel is connected to the motherboard through a simple socket, just pull up to unplug.
  9. Eton FRX3 Solar Panel Replacement: Schritt 9, Bild 1 von 1
    • The solar panel is not glued or soldered in place, you can simply lift the panel straight up from it’s seating to remove.
Abschluss
Jose Mendieta
255 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-6, Nance Spring 2016 Mitglied von USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 424
