Zum Hauptinhalt wechseln
Eufy RoboVac 11S Battery Replacement
Was du brauchst
  1. Eufy RoboVac 11S Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip Robocav Over on the soft side
    • Turn the power switch of the Eufy Robovac 11s to the off position
  2. Eufy RoboVac 11S Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the vac over and use the Phillips to take out the two 5mm screws holding on the bottom cover. Set it aside.
  3. Eufy RoboVac 11S Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift off the bottom cover to expose the internal battery compartment and connector cable.
  4. Eufy RoboVac 11S Battery Replacement: Schritt 4, Bild 1 von 1
    • Find the battery connector inside and carefully detach it to unplug the old battery.
  5. Eufy RoboVac 11S Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the old battery and properly dispose of it.
Abschluss
To reassemble your device, follow these instructions in reverse order. If device still fails to operate complete the guide once again and make sure battery is full connected and charged.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 47
Insgesamt: 388
