Einleitung
The front bumper of the RoboVac 11s is used to sense obstacles in its path. A malfunctioning front bumper can cause the Robovac to move in a circular motion. Use this guide to remove or replace the front bumper on your RoboVac 11s.
Was du brauchst
Using the Phillips screwdriver, remove the eight 5 mm Phillips screws from the top of the bumper.
Lift the bumper slightly and locate the cable connecting it to the main body. Unplug this cable.
