Einleitung
If your RoboVac 11s is having trouble moving around, the issue may come from the drive wheels. This guide will walk you through replacing the wheels and getting your machine working again.
Was du brauchst
Turn off the RoboVac's power and flip it over onto a soft surface.
Use the Phillips screwdriver to remove the four 5 mm screws in front of the wheel being replaced.
Fast fertig!
Abschluss
