Zum Hauptinhalt wechseln
Eufy RoboVac 11S Filters Replacement
Was du brauchst
  1. Eufy RoboVac 11S Filters Replacement, Filters: Schritt 1, Bild 1 von 2 Eufy RoboVac 11S Filters Replacement, Filters: Schritt 1, Bild 2 von 2
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: Schritt 2, Bild 1 von 2 Eufy RoboVac 11S Filters Replacement: Schritt 2, Bild 2 von 2
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: Schritt 3, Bild 1 von 3 Eufy RoboVac 11S Filters Replacement: Schritt 3, Bild 2 von 3 Eufy RoboVac 11S Filters Replacement: Schritt 3, Bild 3 von 3
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: Schritt 4, Bild 1 von 3 Eufy RoboVac 11S Filters Replacement: Schritt 4, Bild 2 von 3 Eufy RoboVac 11S Filters Replacement: Schritt 4, Bild 3 von 3
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: Schritt 5, Bild 1 von 1
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: Schritt 6, Bild 1 von 2 Eufy RoboVac 11S Filters Replacement: Schritt 6, Bild 2 von 2
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: Schritt 7, Bild 1 von 2 Eufy RoboVac 11S Filters Replacement: Schritt 7, Bild 2 von 2
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
felix
181 Reputation
1 Anleitung geschrieben
York University, Team S1-G27, O'Regan Summer 2020 Mitglied von York University, Team S1-G27, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G27
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 87
Insgesamt: 4,799
