Einleitung
Eufy RoboVac 11S won’t work very efficiently when there’s too much dust in the filter. Instead of buying a new vacuum, you can replace some accessories to bring life back to your vacuum robot. This guide shows how to replace the foam filter and high-performance filter in the dust collector.
Was du brauchst
Push the blue button up and open the dust collector.
Empty the dust collector, and throw all the dust into the trash bin.
Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
Take out the foam filter to the side and dispose of it in the trash bin.
Put the pre-filter back in the dust collector.
Use your finger to push the top button first.
Open the back of the dust collector.
Replace the white foam filter.
Put the black high-performance filter at the top of the foam filter.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
