Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before you start, make sure your vacuum is unplugged the power outlet. Press and hold down the black button below the handle while pulling the pole out.
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Press the black separator switch to separate the top and bottom halves of the vacuum. Press the black separator switch to separate the top and bottom halves of the vacuum.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown. Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing. Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  5. Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
    • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
  6. On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing. Re-insert the chrome plated piece into the center track.
    • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
    • Re-insert the chrome plated piece into the center track.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Evan Fodi
122 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 327
