Einleitung
Replace the small wheel or 'roller' on the bottom of the Eureka.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Press the black separator switch and lightly pull the bottom half away from the top. Press the black separator switch and lightly pull the bottom half away from the top.
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Remove the vacuum head from the lower half of the body. Remove the vacuum head from the lower half of the body.
    • Remove the vacuum head from the lower half of the body.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver. Separate the top and bottom of the vacuum head. Set the top aside. Separate the top and bottom of the vacuum head. Set the top aside.
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  5. Turn the vacuum head's bottom over so that the inside of the head is facing up. Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  6. Press the new bar and roller into place.
    • Press the new bar and roller into place.
    • Replace the screws.
Ziellinie
Jennifer Sheils
4 Reputation
2 Anleitungen geschrieben
University of Maryland, Team 1-1, Gulbrandsen Fall 2013 Mitglied von University of Maryland, Team 1-1, Gulbrandsen Fall 2013
UMD-GULBRANDSEN-F13S1G1
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 122
