Zum Hauptinhalt wechseln
Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement
Was du brauchst
  1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement, Brush roll: Schritt 1, Bild 1 von 1
    • Unplug the vacuum from the outlet.
  2. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 2, Bild 1 von 1
    • Use a damp paper towel to clean the bottom of the vacuum of any debris.
  3. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 3, Bild 1 von 2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 3, Bild 2 von 2
    • Flip the vacuum over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 3.0 mm screws.
    • Use a Phillips #2 screwdriver to remove the two 4.2 mm screws.
  4. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 4, Bild 1 von 1
    • Pull the bottom and top cover of the brush roll compartment apart.
    • Internal components of the vacuum may fall out during this step, so keep track of where they are located for reassembly.
  5. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 5, Bild 1 von 3 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 5, Bild 2 von 3 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 5, Bild 3 von 3
    • Lift the brush roll out of the vacuum.
    • The brush roll is connected to two white placeholders on both left and right sides. To remove these, pull them away from the brush roll.
  6. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 6, Bild 1 von 1
    • Thoroughly clean the inside of the vacuum with a damp paper towel and let it dry.
  7. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 7, Bild 1 von 2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 7, Bild 2 von 2
    • To replace the brush roll, attach the two white placeholders on both ends of the brush roll and set them into the corresponding slots.
    • The slots are located on the left and right ends of the bottom cover.
  8. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 8, Bild 1 von 2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: Schritt 8, Bild 2 von 2
    • Reattach the cover and screw it back into place using a Phillips #2 screwdriver.
    • The two 4.2 mm Phillips #2 screws go in the two middle bottom holes.
    • The four 3.0 mm Phillips #2 screws go in the side holes.
Abschluss
Plug in your device and test it to ensure that you have reassembled it correctly.
Mark Parala
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 1-8, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 1-8, Briggs Fall 2022
CSULA-BRIGGS-F22S1G8
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 34
Insgesamt: 835
