Einleitung
If you determine that your vacuum brush roll will not turn and produces a burning smell, this guide will help you to replace the brush roll.
Was du brauchst
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
