Zum Hauptinhalt wechseln
Eureka SuctionSeal 2.0 Pet Brush Roll Replacement
Was du brauchst
  1. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Dust Cup: Schritt 1, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Dust Cup: Schritt 1, Bild 2 von 2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Brush Roll Cover: Schritt 2, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Brush Roll Cover: Schritt 2, Bild 2 von 2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 3, Bild 1 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 3, Bild 2 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 3, Bild 3 von 3
    • Pull up and unhook the two front tower latches using two fingers. These are located at the base of the tower.
    • Pull up and unhook the latch on the back of the tower.
    • Firmly lift the vacuum tower up and out of its stand.
    • The exhaust filter cover can be replaced once the tower is removed. It will not affect the steps.
  4. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 4, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 20mm screws on the top of the vacuum head's cover using a JIS 1 screwdriver.
  5. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 5, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 5, Bild 2 von 2
    • Turn the vacuum head so that the back is facing you.
    • Press the handle release pedal.
    • Rotate the top of the motor cover down while pressing on the pedal release.
    • The motor cover should rotate from an upright position back towards the ground, as it would if the handle were still attached.
  6. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 6, Bild 1 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 6, Bild 2 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 6, Bild 3 von 3
    • Locate the two tabs on the back of the cover.
    • Pull up on the tabs and lift the cover away from the device.
  7. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Belt Latch Assembly: Schritt 7, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Belt Latch Assembly: Schritt 7, Bild 2 von 2
    • Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
    • Remove the two 20mm screws using a JIS 1 screwdriver.
  8. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement: Schritt 8, Bild 1 von 1
    • Lift up on the belt latch assembly and remove it from the vacuum.
  9. Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Brush Roll: Schritt 9, Bild 1 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Brush Roll: Schritt 9, Bild 2 von 3 Eureka SuctionSeal 2.0 Pet Brush Roll Replacement, Brush Roll: Schritt 9, Bild 3 von 3
    • Grab the brush roll on both ends.
    • Lift up on the right side of the brush roll.
    • Lift up on the left side of the brush roll, completely removing it from its frame.
    • Separate the brush roll from the belt and remove the brush roll from the vacuum.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Anna Snyder
336 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S4-G5, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,051
