Zum Hauptinhalt wechseln
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: Schritt 1, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: Schritt 1, Bild 2 von 2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: Schritt 2, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: Schritt 2, Bild 2 von 2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: Schritt 3, Bild 1 von 1
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: Schritt 4, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: Schritt 4, Bild 2 von 2
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: Schritt 5, Bild 1 von 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: Schritt 5, Bild 2 von 2
    • Pull up on the tag and remove the filter.
Abschluss
Anna Snyder
336 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S4-G5, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 616
