Zum Hauptinhalt wechseln
Explorer One HD Wifi Camera Battery Replacement
Was du brauchst
  1. Explorer One HD Wifi Camera Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the camera with the bottom panel facing up
  2. Explorer One HD Wifi Camera Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the 000 size Philips screw head
  3. Explorer One HD Wifi Camera Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully unscrew the panel
  4. Explorer One HD Wifi Camera Battery Replacement: Schritt 4, Bild 1 von 1
    • If you need, use the flathead driver to pry off the cover.
    • If not, simply pull off the panel
  5. Explorer One HD Wifi Camera Battery Replacement: Schritt 5, Bild 1 von 1
    • Once the battery is exposed, simply pull the battery out.
    • You may have to wiggle the battery to pull it out.
  6. Explorer One HD Wifi Camera Battery Replacement: Schritt 6, Bild 1 von 1
    • The battery is connected the camera by terminals for ease of removal
    • Be sure to keep the battery and camera clean during this step
  7. Explorer One HD Wifi Camera Battery Replacement: Schritt 7, Bild 1 von 1
    • push the battery back into the housing gently
Abschluss
Now, your camera is as good as new, have fun!
3 weitere Personen haben diese Anleitung absolviert.
Cameron Smith
400 Reputation
2 Anleitungen geschrieben
Colorado Fixers Mitglied von Colorado Fixers
Community
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 883
