Was du brauchst
IFIXIT Battery pack
You'll need to use a heat gun to heat the adhesive
Take the Jimmy and slide it in the grove and gently pry up and slowly work the jimmy down and around the pack
Once done, you will see the adhesive.
Clean the remaining adhesive off the battery pack
4 weitere Nutzer:innen haben diese Anleitung absolviert.
