Zum Hauptinhalt wechseln
FAO Schwarz Apex 1 Front Wheel Springs Replacement
Was du brauchst
  1. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: Schritt 1, Bild 1 von 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: Schritt 1, Bild 2 von 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: Schritt 1, Bild 3 von 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Wheel Springs Replacement: Schritt 2, Bild 1 von 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: Schritt 3, Bild 1 von 2 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: Schritt 3, Bild 2 von 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Wheel Springs Replacement: Schritt 4, Bild 1 von 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Wheel Springs Replacement: Schritt 5, Bild 1 von 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 202
