Zum Hauptinhalt wechseln
FAO Schwarz Apex 1 Remote Control Battery Replacement
Was du brauchst
  1. FAO Schwarz Apex 1 Remote Control Battery Replacement, Remote Control Battery: Schritt 1, Bild 1 von 1
    • Remove the plastic battery cover to get at the battery compartment.
    • The cover can be removed by pressing down on the lever and sliding.
  2. FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 2, Bild 1 von 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 2, Bild 2 von 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the dead battery, being careful not to damage the internal battery connectors.
    • The battery is a bit wedged in there, so you'll have to press hard to pop it out.
  3. FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 3, Bild 1 von 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 3, Bild 2 von 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the new 6F22 9 volt battery.
    • Line up the positive icons on the battery with the positive icons in the battery compartment.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 497
