Zum Hauptinhalt wechseln
FAO Schwarz Apex 1 Wheel Replacement
Was du brauchst
  1. FAO Schwarz Apex 1 Wheel Replacement, Wheel: Schritt 1, Bild 1 von 3 FAO Schwarz Apex 1 Wheel Replacement, Wheel: Schritt 1, Bild 2 von 3 FAO Schwarz Apex 1 Wheel Replacement, Wheel: Schritt 1, Bild 3 von 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Wheel Replacement: Schritt 2, Bild 1 von 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I have a question about this! I had one of these cars for my son and lost the remote so I ordered another one off ebay. The new one arrived damaged, with one of the rear wheels broken off. The black plastic part on the axle that the wheel screwed into was cracked. So I’m trying to figure out if there is a way to remove this black plastic part from the old car to put on the new one. Or if I can swap out the whole rear axle. I really am not too mechanically inclined, but I want my son to have his remote control car functioning again and I’m really trying to avoid purchasing a 3rd one. Thank you!
Lindsay - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 243
