Zum Hauptinhalt wechseln
Fahrenheit FHT 125PRMR Dial Replacement
Was du brauchst
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: Schritt 1, Bild 1 von 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 2, Bild 1 von 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 3, Bild 1 von 2 Fahrenheit FHT 125PRMR Dial Replacement: Schritt 3, Bild 2 von 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 4, Bild 1 von 2 Fahrenheit FHT 125PRMR Dial Replacement: Schritt 4, Bild 2 von 2
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 5, Bild 1 von 1
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 6, Bild 1 von 2 Fahrenheit FHT 125PRMR Dial Replacement: Schritt 6, Bild 2 von 2
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 7, Bild 1 von 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: Schritt 8, Bild 1 von 1
Abschluss
IUPUI, Team 2-2, Harley Fall 2016 Mitglied von IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 760
