Zum Hauptinhalt wechseln
Fahrenheit FHT 125PRMR Power Cord Replacement
Was du brauchst
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 3, Bild 1 von 2 Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 3, Bild 2 von 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 4, Bild 1 von 2 Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: Schritt 5, Bild 1 von 1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team 2-2, Harley Fall 2016 Mitglied von IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Antwort
Where do you buy the power cord?
Dominique - Antwort
probably available at electronic store
john john - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,459
