Einleitung
If your light is not turning on, then you most likely have a short circuit, which requires a replacement. This guide is specifically meant for incandescent light bulbs under a ceiling mount. It will demonstrate how to remove the broken bulb and replace it with a functional bulb. Make sure there is no current running through the light bulb to avoid electrocution before you begin.
Was du brauchst
Turn off the electrical circuit breaker and the light switch.
Turn the light switch and the circuit breaker back on to check if the light bulb(s) are working before putting the mount cover back on.
Once the light bulb(s) are working, place one hand under the mount. Pull the clip back and let it settle in place.
If the lightbulb does not work after step 7, then you need to get a new lightbulb and repeat step 5-7. If it still does not work then your socket might need a replacement.
