Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Tears and holes in stretched canvas can ruin its usefulness. This guide will explain how these pesky plot holes can be fixed.
  1. A tear can come in all shapes and sizes. Identify your tear and obtain a spare sheet, roll, or square of canvas to fully cover the torn area. A tear can come in all shapes and sizes. Identify your tear and obtain a spare sheet, roll, or square of canvas to fully cover the torn area.
    • A tear can come in all shapes and sizes. Identify your tear and obtain a spare sheet, roll, or square of canvas to fully cover the torn area.
  2. I purchased a small pre-stretchered square of canvas large enough to cover the entire tear. Remove as much of  the canvas from the frame as you can. I purchased a small pre-stretchered square of canvas large enough to cover the entire tear. Remove as much of  the canvas from the frame as you can.
    • I purchased a small pre-stretchered square of canvas large enough to cover the entire tear. Remove as much of the canvas from the frame as you can.
  3. Once you have your square of canvas, ensure the size is correct for the tear you are repairing. Round the edges off with your scissors. This will create an evenly balanced edge which will remove unwanted corners and points that can arise after the gluing process. Once you have your square of canvas, ensure the size is correct for the tear you are repairing. Round the edges off with your scissors. This will create an evenly balanced edge which will remove unwanted corners and points that can arise after the gluing process. Once you have your square of canvas, ensure the size is correct for the tear you are repairing. Round the edges off with your scissors. This will create an evenly balanced edge which will remove unwanted corners and points that can arise after the gluing process.
    • Once you have your square of canvas, ensure the size is correct for the tear you are repairing. Round the edges off with your scissors. This will create an evenly balanced edge which will remove unwanted corners and points that can arise after the gluing process.
  4. PRO-TIP!! When applying your glue to the repair piece of canvas be sure you are putting it on the WHITE side. This will create a cleaner, more blended look to your job and is noticeable to a trained eye. The difference can be seen in the pictures provided. PRO-TIP!! When applying your glue to the repair piece of canvas be sure you are putting it on the WHITE side. This will create a cleaner, more blended look to your job and is noticeable to a trained eye. The difference can be seen in the pictures provided.
    • PRO-TIP!! When applying your glue to the repair piece of canvas be sure you are putting it on the WHITE side. This will create a cleaner, more blended look to your job and is noticeable to a trained eye. The difference can be seen in the pictures provided.
  5. IMPORTANT!! Remove the super fabric adhesive from its packaging. Use your scissors to cut out a rectangular piece from the back of the packaging. IMPORTANT!! Remove the super fabric adhesive from its packaging. Use your scissors to cut out a rectangular piece from the back of the packaging. IMPORTANT!! Remove the super fabric adhesive from its packaging. Use your scissors to cut out a rectangular piece from the back of the packaging.
    • IMPORTANT!! Remove the super fabric adhesive from its packaging. Use your scissors to cut out a rectangular piece from the back of the packaging.
  6. Apply your glue to the white side of the repair piece of canvas and follow up with the cardboard square to spread the glue around on the canvas. An even layer of glue is preferred and should cover the entire piece of canvas. Apply your glue to the white side of the repair piece of canvas and follow up with the cardboard square to spread the glue around on the canvas. An even layer of glue is preferred and should cover the entire piece of canvas. Apply your glue to the white side of the repair piece of canvas and follow up with the cardboard square to spread the glue around on the canvas. An even layer of glue is preferred and should cover the entire piece of canvas.
    • Apply your glue to the white side of the repair piece of canvas and follow up with the cardboard square to spread the glue around on the canvas. An even layer of glue is preferred and should cover the entire piece of canvas.
  7. Proceed by firmly pressing the repair piece of canvas into the canvas like you would a puzzle piece into a puzzle, not pulling in any direction but pushing down. Follow by placing a weight or book on top of the patch and let dry for 1 hour. Proceed by firmly pressing the repair piece of canvas into the canvas like you would a puzzle piece into a puzzle, not pulling in any direction but pushing down. Follow by placing a weight or book on top of the patch and let dry for 1 hour. Proceed by firmly pressing the repair piece of canvas into the canvas like you would a puzzle piece into a puzzle, not pulling in any direction but pushing down. Follow by placing a weight or book on top of the patch and let dry for 1 hour.
    • Proceed by firmly pressing the repair piece of canvas into the canvas like you would a puzzle piece into a puzzle, not pulling in any direction but pushing down. Follow by placing a weight or book on top of the patch and let dry for 1 hour.
  8. Once the glue has dried, assess the patch job. You will notice that the tear has almost disappeared but their is still the matter of the cut in the canvas. Once the glue has dried, assess the patch job. You will notice that the tear has almost disappeared but their is still the matter of the cut in the canvas. Once the glue has dried, assess the patch job. You will notice that the tear has almost disappeared but their is still the matter of the cut in the canvas.
    • Once the glue has dried, assess the patch job. You will notice that the tear has almost disappeared but their is still the matter of the cut in the canvas.
  9. Evenly spread the texture paste in, over, and around the cut. The smoother you can make the edges of your paste, the easier it will be to clean up later. The paste usually takes about an hour or two to dry fully. The goal here is to fully mask the cut with paste. Evenly spread the texture paste in, over, and around the cut. The smoother you can make the edges of your paste, the easier it will be to clean up later. The paste usually takes about an hour or two to dry fully. The goal here is to fully mask the cut with paste. Evenly spread the texture paste in, over, and around the cut. The smoother you can make the edges of your paste, the easier it will be to clean up later. The paste usually takes about an hour or two to dry fully. The goal here is to fully mask the cut with paste.
    • Evenly spread the texture paste in, over, and around the cut. The smoother you can make the edges of your paste, the easier it will be to clean up later. The paste usually takes about an hour or two to dry fully. The goal here is to fully mask the cut with paste.
  10. Once the paste has dried fully, grab your sand paper and begin to carefully smooth out any bumps or edges you can feel. Make sure you have some solid surface behind the area being sanded to avoid creating bumps and deformities in the canvas. Make sure you have some solid surface behind the area being sanded to avoid creating bumps and deformities in the canvas.
    • Once the paste has dried fully, grab your sand paper and begin to carefully smooth out any bumps or edges you can feel.
    • Make sure you have some solid surface behind the area being sanded to avoid creating bumps and deformities in the canvas.
  11. After the sanding process is finished, we apply a final layer of Acrylic Gesso. You can apply it with a small or medium brush. Let it dry for 1 hour. After the sanding process is finished, we apply a final layer of Acrylic Gesso. You can apply it with a small or medium brush. Let it dry for 1 hour. After the sanding process is finished, we apply a final layer of Acrylic Gesso. You can apply it with a small or medium brush. Let it dry for 1 hour.
    • After the sanding process is finished, we apply a final layer of Acrylic Gesso. You can apply it with a small or medium brush. Let it dry for 1 hour.
  12. After your Acrylic Gesso has dried, you are done! Congratulations! Your canvas should be repaired and fully usable for your painting needs. I hope this tutorial was helpful and informative.
    • After your Acrylic Gesso has dried, you are done! Congratulations! Your canvas should be repaired and fully usable for your painting needs. I hope this tutorial was helpful and informative.
Abschluss
These steps should help you to completely repair a tear in stretched canvas.
Luke Dixon
121 Reputation
1 Anleitung geschrieben
Michigan Tech, Team S5-G12, Galliah Fall 2017 Mitglied von Michigan Tech, Team S5-G12, Galliah Fall 2017
MTU-GALLIAH-F17S5G12
1 Mitglied
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 9
Letzten 7 Tage: 70
Letzten 30 Tage: 303
Insgesamt: 3,600
