Zum Hauptinhalt wechseln
Tonneau Trifold Bed Cover Retention Pin Replacement
Was du brauchst
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: Schritt 1, Bild 1 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: Schritt 1, Bild 2 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: Schritt 1, Bild 3 von 3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 2, Bild 1 von 2 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 2, Bild 2 von 2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 3, Bild 1 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 3, Bild 2 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 3, Bild 3 von 3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 4, Bild 1 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 4, Bild 2 von 3 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 4, Bild 3 von 3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 5, Bild 1 von 2 Tonneau Trifold Bed Cover Retention Pin Replacement: Schritt 5, Bild 2 von 2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
Abschluss
To reassemble your device, follow these instructions in order.
Christopher King
139 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
25 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 705
