Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A broken asphalt roof shingle will be repaired through this guide. Roof shingles, especially asphalt ones, wear and tear after years of sun damage, rain, and heavy wind. They need to be replaced because water can get under the broken shingle and cause the wood to rot or create a leak in the roof. The guide will be specific to repairing one tab of the shingle sections.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Use caution when handling a hammer and nails.
  2. Remove the single broken shingle, carefully, without ripping out the shingles above.
    • Remove the single broken shingle, carefully, without ripping out the shingles above.
  3. Remove the adhesion strip off of the new shingle.
    • Remove the adhesion strip off of the new shingle.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Slip the new shingle in place, and line it up where the old shingle previously was.
    • Slip the new shingle in place, and line it up where the old shingle previously was.
  6. Secure the shingle with three 7/8" roofing nails. Be careful when hammering in the nails.
    • Secure the shingle with three 7/8" roofing nails.
    • Be careful when hammering in the nails.
  7. Slightly lift the edges of the shingle and apply a thin layer of cement along it.
    • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
  8. Press down the edges to lock the shingle in place.
    • Press down the edges to lock the shingle in place.
Abschluss
Marie Albrecht
145 Reputation
1 Anleitung geschrieben
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 127
