Zum Hauptinhalt wechseln
Faulty Plug Prongs Repair
Was du brauchst
  1. Faulty Plug Prongs Repair, Faulty Plug Prongs Repair: Schritt 1, Bild 1 von 1
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Faulty Plug Prongs Repair: Schritt 2, Bild 1 von 1
    • If the prongs are bent out of shape, take the pliers and slowly apply pressure so that the prongs bend back to their regular shape.
    • It doesn't have to be perfect. It just has to fit into the outlet.
  3. Faulty Plug Prongs Repair: Schritt 3, Bild 1 von 1
    • Plug the power cord into the outlet and make sure that it's connected to the device.
Ziellinie
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 7-50, Forte Fall 2012 Mitglied von Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
What if the casing is broken and needs to be replaced?
Bertha Torres - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 51
Letzte 30 Tage: 207
Insgesamt: 16,636
