Zum Hauptinhalt wechseln
Fellowes T7CM Trigger Assembly Replacement
Was du brauchst
  1. Fellowes T7CM Trigger Assembly Replacement, Fellowes T7CM Casing and Trigger Replacement: Schritt 1, Bild 1 von 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    Frag FixBot
  2. Fellowes T7CM Trigger Assembly Replacement: Schritt 2, Bild 1 von 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    Frag FixBot
  3. Fellowes T7CM Trigger Assembly Replacement: Schritt 3, Bild 1 von 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    Frag FixBot
  4. Fellowes T7CM Trigger Assembly Replacement: Schritt 4, Bild 1 von 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    Frag FixBot
  5. Fellowes T7CM Trigger Assembly Replacement, Trigger Assembly: Schritt 5, Bild 1 von 1
    • Remove the trigger assembly by gently twisting and pushing it.
    • The assembly should come off easily with little effort.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 2-2, Baechle Fall 2016 Mitglied von IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 50
Insgesamt: 3,189
